SOURCE: huskey pressure washer 2600 the water works but
Hello kjc33;
Do you know that the unit must be on low pressure to apply soap. The control is usually on the nozzle
SOURCE: Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
