Question about Jacuzzi Home
Do EuroHouse jacuzzi spa bath pumps have a on/off bellows switch that switches off the motor when the bath is empty ?
SOURCE:
  • 152 Answers
SOURCE: Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Posted on Feb 22, 2009
PartsCenter
  • 125 Answers
SOURCE: Kohler bathtub spa does not work at all
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
Posted on Feb 24, 2009
  • 61 Answers
SOURCE: My jacuzzi keeps emptying into the pool when the
I agree it sounds like a check valve. if the water in the pool matches the water level in the spa, or drains all the way (depending on how far the spa is raised) then it is the valve before the pump, but if it goes down to the jets (and not any further) then it is a check valve or valve on the retun side of the plumbing ( after heater or chlorinator).
Posted on Apr 04, 2009
SOURCE: Jacuzzi - GFCI keep tripping prventing Jacuzzi
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
Posted on May 16, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
How do I replace the on/off switch on my jacuzzi pool pump
you might not be able to replace the switch parts might not be available jacuzzi is out of business you might be able to replace the motor if not get a new pump they can cross reference for you
Jul 28, 2014 | Jacuzzi Pool & Spa
Jacuzzi Amiga motor does not tuen on. Hardly ever used
There are no reset buttons on bath pumps. It may be the motor is bad or the toggle switch is bad.
US Parts Center
Jan 26, 2014 | Jacuzzi Amiga Whirlpool JAC-N888...
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 06, 2013 | Kohler Home
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Jacuzzi outdoor bath tub i have there is power but the bubbles thing isnt working
Find the plug for the pump and plug it in ( tub full of water), if the pump works,the problem is in the contol box or switch. if the pump/motor has a plastic tube coming out of a black box, and the pump still does not work when plugged in, it is most likely the air switch connected to that plastic tube on the pump. the switch is avaliable online and not to hard to replace if you are mechanically inclined.
Sep 26, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Feb 21, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
82 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
