SOURCE: How to reset Service 4wheel drive warning light on 2005 ChevTahoe
I have a 2005 Tahoe that recently had a similar problem. To resolve, I did the following.
This will cycle the fluid within your transfer case, and hopefully clean out the sensor. I did this, and my Service 4WD light went away after one day of normal driving. Hope this helps. Note: When I went into 4L the first go around, it had a hard time shifting due to non use. I changed between 4H and 4L a few times until it got smoother.
SOURCE: Perform Service light reset
1.Turn key on/eng off
2.Press brake pedal slowly 2 times
3.Press gas pedal 2 times within 10secs.
4.Turn key off
SOURCE: Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
SOURCE: how to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Mike, can you send me the file of Part List for this Air Dryer FD160? I really need it. If you guys have too, please send me an e-mail to [email protected] thankyou
