Cars & Trucks Logo
Cherrush Petunia Posted on May 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the fuse that is titled panel in the passenger side fuse box on a 1999 Lexus GS 300 power and control?
loginek
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Lexus Master 1,075 Answers
  • Posted on Jul 01, 2017
loginek
Lexus Master
Level 3:
Renaissance:
Answers
1075
Questions
0
Helped
1319447
Points
4975
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 31, 2009
SOURCE: Power windows and Power side mirrors Will not work.
i have had this issue before all i had to do is do a new ground, jumped the safety window lock, as well as expanding the metal clips in the wire con.
adnanbhatti
Adnan Bhatti
  • 1188 Answers
  • Posted on Jul 30, 2009
SOURCE: The passenger side front and rear power windows 2005 Lexus ES
Fuse is blown. Replace fuse for the said windows.
Anonymous
  • 17 Answers
  • Posted on Aug 18, 2009
SOURCE: Replace front side running light in a 2000 Lexus RX300
Unscrew 3 - 4 screws on the front tire fendor cover close to your side marker light. Pull the fender cover out, use your other hand to reach the side marker light. Using twist and pull the light set out. Replace a new light bulb. Replace everything in a reverse order.
Anonymous
  • 185 Answers
  • Posted on Oct 10, 2009
SOURCE: Doors won't lock with remote on my 2002 Lexus GS 300.
are you sure the battery is good in the remote? if so try putting the key in the driver door lock and locking and unlocking the doors three times in a row. if this dosent work i suggest taking it to an experienced lexus shop.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Feb 24, 2012
SOURCE: 99 lexus gs 300 fuse box diagram
We do not have the owners manuals for any model of Lexus. they are not free to download, you must purchase them from Lexus/Toyota
Where is the power fuse on lexus gs 300 located?
On this website, you find fuse box diagram and description for Lexus GS300
http://www.autogenius.info/?s=gs300
2answers
Lexus GS 300 AC on Drivers side, Heat on Passengers side
most likely the AC head unit has gone bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Lexus GS 300 AC on Drivers side, Heat on Passenger side
You will more than likely need to replace the whole heater control unit in the dash. Thier like mini computers now and usually if one side goes down it means the whole unit is shot.
2answers
Lexus GS 300 driver's side power seart is jammed. Ineed to remove it - can you help
Hi, there are two ways to this problem. First of all, check the fuse box for a blown fuse, the seats operate on fuse which if burnt will not make the seat work. The fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side. Secondly, if it isn't a fuse problem, you have to replace the power motor so it can work again, I can imagine it's gonna cost a lot for your lexus, Normally this happens because of constant use.
7helpful
2answers
HOW TO REPLACE 100A FUSE ON 1994 LEXUS GS300
The 100 Amp alternator fuse is blown under the hood in the fuse block, it has a clear plastic cover on it for inspection, the designation is marked inside the fuse panel. This fuse is bolted in inside the fuse box, the fuse box has to be removed and opened to get to the bolts that connect the fuse in.
Here you have the Lexus-GS-300-Wiring-Diagram-Manual
Good luck (remember rated this help).
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Lexus Expert? Answer questions, earn points and help others
