Watches Logo
Kerry Posted on May 30, 2017
Beware i bought some nike trainers from facebook, i kmow i here you say but it was a bit funny when i was going down the road and the N fell off lol
Where can I buy the strap of my Nike wc0021?
Check in Here I just bought a damaged part of my Nike Hammer that I've been looking for about years!!! Don't gave up your awesome watch!!! www.easycarts.net
1helpful
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
One of the screws that connects the band to the body of the watch fell out. Is there any way to replace screw without sending it in to Nike? What size screw would I need if I went to the hardware store?
It is unlikely that any hardware store will have the size of screw that you need, since watch screws tend to be much smaller than are generally available.
The best place to go is a watch shop. They should be able to get it replaced for you.
9helpful
2answers
Just got a nike anvil comold but cant get the backlight to work
I had the same problem. The seller told me to reset the watch by pressing down on all four buttons at once. Sure enough, the backlight function was enabled again.
Nike Preto Watch
http://www.nikewatchrepair.com./nike_models.htm
Nike triax speed WR0082 regular
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
Top Nike Watches Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a Nike Watch Expert? Answer questions, earn points and help others
