Televison & Video Logo
Johan Grobbelaar Posted on May 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha BD 671 desplay "please wait" the hole time? What is wrong?
Level 3:
Top Expert:
  • Yamaha Master 76,851 Answers
  • Posted on Sep 12, 2019
Yamaha Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006994
Points
237762
Sounds like system control [memory] section fault. This is not a user repairable fault. Contact the service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Printer problem 2075
disconect the hard drive from the machine
Factory reset button
Yamaha BD- S473 / 673 (factoy reset resolves cinavia problem)
I do it i do it, and i dot only by myself, proceed as follow (with out disc inside) just pick the "stop" bottom at the same time to puck up the "pause" bottom for more than 5 second, then will appear in the device display "F-RST yes", and continue press in up the 2 bottoms and the device turn off automatically, after you can turn it on an configure settings as new (cinavia problems keeps off)
Regards
Choss
IS IT POSSIBLE TO CONNECT RX- V559 WITH BLUE RAY PLAYER
Yes. Assuming you unnamed BD player has digital audio output that is compatible with one that's available to use on the Yamaha.
OTOH, the coaxial digital input CAN be shared if you use an RCA-Y cable and make sure only ONE of the shared inputs is turned on anytime you use it.
If the BD also has Component Video conenctors you could run them TO the Yamaha, too, but I would opt for the BEST video from the BD to go directly to your TV or monitor, even bypassing the AVR if necessary. The fewer intervening connections and conversions, the better.
1helpful
After using sp/dif out, from EMu-PX7 to yamaha aw-160. Error message "wrong word clock"on yamaha, non-functional until px7 is connected via sp/dif, on, and fully booted up?
im not sure which item is displaying the error message, you werent too clear on that. i think that the yamaha is the one displaying the message.
what has happened is the unit having the error message set itself to use the other device's clock as a digital timing master. there is some way, inside the device in question, to go through the menues and find a selection for "clock source" . you want the "clock source" set to "internal" for it to operate independently.
if you tell me for sure which device is desplaying the message, i *might* be able to find out where in the menu you have to go to find the "clock source" selection, but, without a manual, it would be very hard for me to figgure it out for you. if you have a manual for the device, you need to search through it for the "clock source" menu feature. if you dont have a manual;, you would prolly have better luck searching for "clock source" in the menus then i would have locating a manual for you. its not impossible to find it fiddling through the menu, now that you know for what to look.
8helpful
3answers
How to unlock region code for Yamaha-BD-S1065-Blu ray-Players
download.yamaha.com/api/asset/file/?language=en&site...yamaha...
www.4electronicwarehouse.com/.../yamaha/bd-s1065-blu-ray.pdf - United States
There are NONE at the moment, Please have a look at these manuals above they will assist you.
Check out this master Google link...
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=unlock+region+code+for+Yamaha-BD-S1065-
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
