SOURCE: Crankshaft pulley (vibration damper) moved forward.
the pulley is also a dampener often times they seperate from each other. replace pulley/dampener.
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
SOURCE: I need a drive belt diagram for a MTD mod# 13am77f7000 38''cut
Hi check out this site its called pats small engines just look up your model
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
SOURCE: I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
