SOURCE: my 2007 yamaha v star 650 keeps blowing the fuse
There seem to a 'live' wire (in the turn signal, brake light or horn circuit) touching the frame of the bike and thus the fuse blowing.
You will have to trace out the short-circuit.
You can start wth removing the connections to the turn signals thn fit the fuse and see if it still blows ....like wise remove the wire to the brake light and thn check if the fuse blows, same to the horn.
In short ..you can remove all the wires connections to these and thn fit the fuse and refit the wiring connections one by one ,where the fuse will blow after connecting the wire to say brake light thn the problem is at the brake light wiring ....likewise to the others ...onces you identify the circuit tht has the problem thn it will be easy to trace it and rectify it.
Hope this helps!
SOURCE: gauges blow fuses,brake and turn signal lights dont work
all my gauges quit working and my turnsignals checked all my fuses under the hood and dash whats my problem?
SOURCE: how can I install a horn in a battery powered golf cart?
easy hook up.. the 12 horn should have 2 wires, a red and a black hook the red one to 12 volts with a 5 amp fuse in line, take the black and run it to one side of a push button switch (with 2 wires) the other wire coming out of the horn with go to ground, either to the battery ground or to the frame of the cart..
SOURCE: Brake lights,turn signal and horn not working...
Check the wiring within the headlight shell--look for connectors that may be corroded or pulled loose. A little WD-40 will favor connection integrity when sprayed into the connectors, then coupling and uncoupling them several times. Hope this helps!
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
