Washing Machines Logo
M
Mark Posted on May 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Fisher & Paykal washsmart top loader just will not turn on on lights nothing, was on just powered up and then we turned off the machine at the power point and has not worked since
Greg Stephen
Level 2:
  • Fisher Expert 566 Answers
  • Posted on Aug 27, 2017
Greg Stephen
Fisher Expert
Level 2:
Answers
566
Questions
Helped
224746
Points
688
The power supply just needs to be repaired.
Little chip near the small transformer needs replacing.
5 Related Answers
Anonymous
  • 70 Answers
  • Posted on Feb 28, 2009
SOURCE: I HAVE A FISHER AND PAYKEL TOP LOADER MODEL GW609
you could have a jammed power or sart\pause button, these quite often get corrosion on the PCB and then the switches fail ON, if you can turn the machine on it is not dead, it can be repaired but you might want to get a technician in to reapair PCB. Also it would be helpful to know what lights light up when in error mode.
Anonymous
  • Posted on May 22, 2009
SOURCE: Washing machine won't turn on
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
Anonymous
  • 71 Answers
  • Posted on Jan 06, 2010
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
luisa_sgro
  • 713 Answers
  • Posted on Jul 27, 2010
SOURCE: washing machine stopped during spin cycle
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Sam
  • 3247 Answers
  • Posted on Oct 04, 2010
SOURCE: Fisher & Paykal DD6031 Integrated We have a
The fault you have described with the top drawer appears to be related to the lid seal becoming dislodged. However, I am slightly unclear if you can actually open the drawer or not. YOu mention it is hard to pull but you also say you see water at the bottom of the drawer. So I am assuming you are able to open the drawer. This is important otherwise it will become hard to check the problem.
It might help confirm if the lid seal is the problem if you can check which lights are on at the top of the drawer lid. For example NORMAL and RINSE. I am assuming since you have an integrated model there is no LCD display in the front.
If it is a lid seal problem then you may have to call the technician from Fisher and Paykel. It does involve a little patience and mechanical prowess to fix it. There is fiddling with motors etc involved.
You can check the parts out at this site.
Fisher & Paykel washsmart washing machine model wa1068g1 was displaying error PUE-F and now will not switch on there appears to be no power to the unit
Pump Impeller is jammed cannot turn
has over-current power supply.
Small black chip near the small transformer has blown.
I HAVE A FISHER AND PAYKEL TOP LOADER MODEL GW609 - Wont Power Up I have managed to access the error code and 3 Lights are on and the Unit beeps continually every second. Can anyone please help to tell me...
23helpful
5answers
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
