Tools & Hardware - Others Logo
Greg Clarke Posted on May 28, 2017
Nail gun Wont fire - Tools & Hardware - Others
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Aug 27, 2008
SOURCE: Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Anonymous
  • 104 Answers
  • Posted on Oct 22, 2008
SOURCE: paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Chuck Nelson
  • 24 Answers
  • Posted on Apr 14, 2009
SOURCE: Paslode nail gun will not fire
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
John Trevino
  • 1420 Answers
  • Posted on Apr 27, 2009
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Anonymous
  • 10865 Answers
  • Posted on May 20, 2009
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
1helpful
2answers
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
1helpful
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
I have a paslode airless framer that wont fire. New batterry & fuel cell. It make the noise but wont fire
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
Hitachi NR 83A2S, Nail wont fire properly
The NR83a has an adjustment just below the triggering plunger. It is a 6mm hex head bolt with a locking nut. Loosen the nut and adjust screw out several turns and re-test. Make adjustment as necessary. I have seen many of these gun without the locking nut which allows the bolt the adjust itself all the way down. AS parts wear this screw needs to be adjusted. The pushing lever and the plunger are wearing smaller/shorter, that is unless the locking nut was missing. Remove gun from air supply for safety when making adjustments. Good Luck an email if you have other qustion about this gun.
2answers
Nail Gun Problem
1helpful
Nail Gun Problem
1helpful
3answers
Nail Guns Safety problem
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
