SOURCE: Sanyo CE28 WN7-B TV
French TV works on a diffrent frequency to uk i cannot remember the details but one is PAL as memory serves me a modern tv should switch over in the settings
Anthony
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
SOURCE: I want to add a DVD recorder into my TV set up
If I'm right On the DVD recorder there should be an aerial input and an output. Connect external aerial to the output then run a second from the output to the TV. Then use the HDMI to connect the DVD. This will then give you the option of recording one channel on the DVD whilst watching another thru the receiver thats built into the TV. You will then get the best poss picture when viewing DVD
SOURCE: cant connect playstation 2 to LG lcd tv
I have a sony bravia lcd digital color tv. I want to know how to plug in my play station 2? The PS2 has a coaxial cable running from it with a side coaxial connection. Where an how do i connect?
SOURCE: my function for memorize channels isn't working (trutech tv), how do i troubleshoot this problem
how to unlock on videocon tv
Did you fix your issue? I have the 43 inch Luxor smart tv and it won't open any apps because it says I need to be connected via the aerial too. I don't have an aerial connection. Hence why I bought a smart tv.
No haven't managed to yet. Think we'll need to buy an aerial for it. My daughter mostly runs her laptop through it now . She can watch youtube and netflix as well through the apps but that's about it!
