What if the. machine makes a scrutching sound,shows no error message and will not allow any flow of notes?What if the. machine makes a scrutching sound,shows no error message and will not allow any flow of notes?
You can't post conmments that contain an email address.
Glory UW-500/600 Currency Sorter (No longer available, please see UW-F) dead.
it needs service. take it to a shop and get some.
cleaning out is first. money is nasty dirty stuff.
There are a lot of reviews out there indicating the Mag Nif coin sorter works poorly or breaks easily. I recommend returning it. See review at links below
Let me set the record straight. Brandt invented the 8672, one of the best machines of all time. Unfortunately it was way over priced. Brandt was in business for over 110 years and then sold out to the employees of the company who then sold out to the DeLaRue company in England. DeLaRue then sold out to Talaris. And, finally, Talaris sold out to Glory two years ago. However, the 8672 stopped production before Glory became the owner. All the above took place over 15 year period. Got all that!!
Now back to your question. What kind of manual do you need? I would need to know the full model and serial number for the correct manual.
If your counter say Brandt on it, that is very old. The newest version has the name Talaris on it. Spare parts can be had, but are very rare and somewhat expensive since the machine is no longer made. Here is a picture of a 8672. Good luck.....
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
F1 00 Content Sorter communication trouble
Detail Communication line test error occurs when
power is turned on or after the exit of a
simulation mode.
Improper communication with sorter
Cause Improper connection or broken wire of
connector or harness between copier and
sorter
Sorter control PWB defective
Control PWB (PCU) defective
Malfunction due to noise
Check
and
remedy
Clear by turning the power supply OFF/ON.
Check communication line connector and
harness.
Replace sorter control PWB or PCU PWB.
F1 02 Content Sorter transport motor error
Detail Transport motor drive trouble
Cause Motor lock
Check
and
remedy
Check transport motor operation with
SIM3-3.
F1 03 Content Sorter guide bar rocking motor trouble
Detail Sorter guide bar rocking motor drive error
Cause Motor lock
Motor speed error
Overcurrent to motor
Check
and
remedy
Check guide bar motor operation with
SIM3-10.
F1 04 Content Sorter indexer lower limit detected
Detail Indexer has exceeded lower limit.
Cause Sensor defective
Check
and
remedy
Check sensor with SIM3-2.
F1 05 Content Sorter indexer upper limit detected
Detail Indexer has exceeded upper limit
Check
and
remedy
F1 06 Content Sorter bin shift motor error
Detail 1) Bin shift is not completed within 2.5
seconds after bin shift request
Cause Motor lock
Improper motor speed
Check
and
remedy
Check bin shift motor operation with
SIM3-4.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
CH - open cover in the paper feed area.OR - Sorter not installed properly CH blinking - Dev unit is not properlyinstalled.
EE-EU - Low toner density in thedeveloper.
Check/ replace toner cart. Check/ reset Dev. unit. Check covers and doors to make sure all are closed properly. If you have sorter -- make sure sorter is seated properly.
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
