SOURCE: serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
SOURCE: Sony stereo serial number
The player will have to be removed from the dashboard and the Serial Number will be on a label on the radio casing
It should begin with M or V or L or C
SOURCE: Cant read the serial # on 2N ford tractor. How do I find out the
They were only made from 42 to 47, I know you can make the serial number visible using ferric chloride? It is a heavy acid, etches copper fast, and will bring out a stamp in metal. The PD uses it all the time on guns and such. If you know where the serial is, you can read it. I don't know if you can buy less than a pound of the stuff, maybe. If not , let me know, I have a lab here, all kinds of stuff. Hope this helps.
SOURCE: I recently bought a Craftsman
Usually the quickest way to date lawn tractors is to look for the date code (Briggs and Stratton) or the D.O.M. (Tecumseh) for example. So on a Briggs engine there is a long three part series of numbers: model; type; and code. The code is the date code and the first two digits are the last two digits of the year made, the next two are the two digit month, followed by the next two which are the two digits for the day. This is how I get a decent idea of the age of a mower, assuming the original engine is on the machine of course. If you have a Tecumseh engine, it has a four digit DOM before 2004 and a five digit from 2004 on. The first digit of the four digit version is the last digit of the year. From 2004 on with the five digit the first two digits represent the last two digits of the year. Either way with Tecumseh engines the last three digits would be the day of the year. For example a Tecumseh engine 05222 would have been made on August 10, 2005. If you have a Kohler, I am not sure about that one as I have not had to date one yet, but the vast majority of the engines I deal with for Craftsman, including my own are Briggs and Stratton.
I hope you find this helpful.
YOU CAN TRY GETTING THE CODE FROM UNDER IT OR AT THE VERY BACK.. THAT IS HOW I GOT IT.. IF IT DOES NOT SHOW..REQUESTED AT WWW.BESTDIRECTORYSOLUTIONS.COM ITS FREE
