SOURCE: Mixer not creaming butter and sugar...
make sure you are using the right attachment. usually for batters you want to use the flat beater. not the dough hook. the flat beater looks like a triangle with lines through the center. and make sure you are using the correct speed on the mixer. start out at stir and then go up to no more than half speed. these mixers take a little longer to incorperate batters but they do a very good job at it. if the batter is thin enough you can try using the wisk as well. but only if it is a thin batter.
SOURCE: Kenwood Chef model A901 smoke & burning electric smell from motor
there is a kit on ebay for both 701 and 901 kenwoods requires use of soldering iron do a search for Kenwood motor repair it is unlikely to be the motor usually the speed contoller components
SOURCE: kenwood mixmaster spare parts
Hello you need a complete mincer, or a mincer part ?
try in 4kenwood.co.uk ( be careful )
or in Ebay.co.uk
Billingtonelec.co.uk
regards
Kenwood Chef Restore
SOURCE: Does anyone know the model number of a stainless
The model number doesn't really exist other than the fact that the stainless steel bowl is available for just about every Chef made. My own KM300 has a stainless steel bowl for example that came as standard - it however is the same bowl you can order from Kenwood or EBay under the A701/A901 model - all bowls from Kenwood can be fitted on the Chef model with the exception of the Major model which is a larger and taller machine.
