SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
Short Bolts:
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
SOURCE: head bolt torque specs for 2000 dodge neon 2.0 SOHC
I have the specs and diagrams. If you want me to send them to you, give me your email address. [email protected]
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
