Question about Kohler Home
My Kohler Touchless will not make a complete revolution when flashing. It rotates to the ten o'clock position and stops. This leaves the flush valve open. Not enough torque? Have tried several new bat
6ya staff
SOURCE:
robocop
Bill Batross
  • 90 Answers
SOURCE: Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
Posted on Jan 23, 2009
Anonymous
  • 32 Answers
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Posted on Aug 16, 2009
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
Anonymous
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
  • 6046 Answers
SOURCE: The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Posted on Feb 19, 2010
How do I fix KOHLER Touchless toilet it keeps flushing, it is less than 6 months old
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Oct 01, 2014 | Kohler Home
I replaced my fluid master and now it will not stop filling in the tank.
Try lifting the float part of the valve. If the water stops filling, reset the float level lower.
If water does not stop when lifting the float, flush out the valve according to the instructions - steps 12 - 15.
12. IMPORTANT: Always clear sand and rust from system. Make sure
water supply is shut off. Remove valve TOP by lifting arm and rotating
top and arm 1/8 turn counterclockwise, pressing down slightly on cap.
13. While holding a container over the uncapped VALVE to prevent
splashing, turn water supply on and off a few times. Leave water
supply off.
14. Replace TOP by engaging lugs and rotating 1/8 turn clockwise. MAKE
CERTAIN TOP IS TURNED TO THE LOCKED POSITION. VALVE MAY
NOT TURN ON IF TOP IS NOT FULLY TO THE LOCKED POSITION.
15. Turn on water supply. Adjust water to desired level by squeezing water
level adjustment clip and moving FLOAT CUP up or down along stainless
steel link. Check for leaks, then check for proper flush.
If valve continues to run:
IF FILL VALVE WON'T TURN OFF,
• There may be debris at seal - repeat Steps 12-15.
• The seal inside the valve top may be damaged -replace with genuine
Fluidmaster 242 seal.
Nov 29, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
My rockerarms are loose on my 2.2liter engine. how can i adjust them?
Adjust the valves when the lifter is on the base circle of a camshaft lobe:
  1. Crank the engine until the mark on the crankshaft pulley lines up with the O mark on the timing tab. Make sure that the engine is in the No. 1 firing position. Place your fingers on the No. 1 rocker arms as the mark on the crank pulley comes near the O mark. If the valves are not moving, the engine is in the No. 1 firing position. If the valves move, the engine is in the No. 4 firing position; rotate the engine one complete revolution and it will be in the No. 1 position.
  2. When the engine is in the No. 1 firing position, adjust the following valves: Exhaust - 1,3 Intake - 1,2
  3. Back the adjusting nut out until lash can be felt at the pushrod, then turn the nut until all lash is removed (this can be determined by rotating the pushrod while turning the adjusting nut). When all lash has been removed, turn the nut in 1 1 / 2 additional turns, this will center the lifter plunger.
  4. Crank the engine one complete revolution until the timing tab and the O mark are again in alignment. Now the engine is in the No. 4 firing position. Adjust the following valves: Exhaust - 2,4 Intake - 3,4
May 12, 2010 | 1992 Chevrolet Cavalier
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
What is the procedure for replacing the flush valve assy on a san raphael toilet. it is a one piece tank and bowl assy and must install from the inside of the tank. it appears to possibly rotate into place...
If you purchase the flush valve from Kohler, it comes without instruction. Rotation is the key to removal. First note the exact orientation of the assembly before attempting removal. Unhook the flapper chain and remove the flapper. The old assembly does indeed rotate in either direction for removal. I used a counterclockwise motion. (it was a tough turn, don't break the bottom of the bowl where the valve seat is located.) Then install the new foam gasket on the assembly. The new assembly is replaced in the reverse manner. I removed the new flapper from the flush valve for ease of install. You must put significant downward pressure on the flapper seat while rotation is accomplished. Orient the assembly as was the old one. Replace the flapper, connect the chain and observe the flapper for proper opperation.
Oct 03, 2009 | Kohler K-3384-2-0 San Raphael elongated...
Airbag light flashes 4 times and pauses
browntoni22: the code it self is "Potential short in Air Bag system"
CAUTION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You are playing with Explosives!!!
Working on a safety restraint system can be very dangerous if you don't know what you are doing. There is a procedure to diagnose the problem which entails using a jumper wire for part of the diagnosis. Just as an example: emissionwiz mentioned a clock spring. This can be damaged by the installer very easily if they don't know what they are doing.
It is designed to rotate only so many revolutions. IF the installer was not paying attention and the clock spring had been out of the packing prior to their receiving it, it could have been rotated one or several revolutions. So when the installer puts the clock spring in place and goes to turn the steering wheel in one direction, it's fine but in the other direction, it will destroy the part!
Anyway, to sum it up in a nutshell, leave this job to a pro.
Apr 02, 2009 | 1990 Lincoln Town Car
Home Logo
795 people viewed this question
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
