Garden Logo
Alex Y. Posted on May 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Homelite 26cc highspeed surges - Homelite Garden
  • Alex Y.
    Alex Y. May 25, 2017
    I have tried adjusting both mixture screws. At full throttle after about 30 seconds the idle surges up and down.
  • Alex Y.
    Oops ! It should have said the high speed surges up and down. Not the idle.
roeb
Level 3:
  • Homelite Master 819 Answers
  • Posted on Nov 21, 2017
roeb
Homelite Master
Level 3:
Answers
819
Questions
0
Helped
385205
Points
2343
Repost with UT number.
5 Related Answers
roeb
  • 819 Answers
  • Posted on Apr 29, 2009
SOURCE: Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Anonymous
  • 144 Answers
  • Posted on Aug 12, 2010
SOURCE: Replace a primer bulb on a Homelite Mighty Lite
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Oct 15, 2010
SOURCE: NEED TO REPLACE SPARK ARRESTER
Hi and welcome to FixYa. I am Kelly.
There are 6 model numbers with Mighty Light in the name:
UT-21506
UT-21546 UT-21907 UT-21947 UT-21566 UT-21967 They all appear to use this muffler: http://www.jackssmallengines.com/partslookupcart.cfm?arisku=308990001&aribrand=Homelite&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dAnjgY*mKGXmndGJGQbyJww%253d%253dariamparica%253dwBQND3HPqCdAJrT8YcDNyA%253d%253dariamparioem%253dVOGGWB2rODFgBxRc4uyLwQ%253d%253dariamparit%253da439d57a-1a88-41c6-a006-f87871a54b42&ariqty=1 If this is not what you were looking for you can go to this site and find your model number. Just note that homelite engines are usually in the 2nd drawing of each unit: http://www.jackssmallengines.com/help.cfm Choose parts search by model (Folders) Homelite Homelite (again) String Trimmers Then search for your model number The engine is under general assy. It is replaced by simply unscrewing the mounting screws / removing the muffler and then mounting the new muffler using the original hardware and reverse sequence of removal for gaskets and heat shields. Thanks for choosing FixYa, Kelly
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Jul 02, 2011
SOURCE: how to remove the string
Here is a manual similar to your owners manual. See pages (13 and 14 ) inside for instructions on this procedure.
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Aug 20, 2011
SOURCE: i cant figure out how to change the string on my
Here is my Tip on this problem:
www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
Jim
Have spark dos'nt start ? homelite 26cc
Since you have spark then you need gas or air. I made some videos on giving my Homelite a tune up and carb rebuild. Got all the parts form Home Depot and the carb rebuild kit from Amazon. Didn't cost much for all that.
Homelite 26cc hk18
Don cenrtal spares should have them. check the web site
Where can i get a Gear & Pin Assembly for my homelite
I am pretty sure that John Deere still owns Homelite. When I had a Homelite chainsaw I went to a John Deere implement dealer and they ordered it for me.
2helpful
2answers
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
1helpful
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
