SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
SOURCE: how do you adjust the valves on a 17.5 ohv briggs
Hi 1st remove the rocker cover and spark plug
hold a long skinny screwdriver down the plug hole and wind the engine by hand until you get top dead centre (NOTE WATCH ROCKERS) first the intake valve will open then close when it closes the piston should be coming up to top dead centre and both valves should be closed and the rocker loose setting should be 0.004 thou you need to undo the locking screw down the centre of the adjusting nut then you can adjust to setting, (DONT FORGET TO DO THE LOCKING SCREWS BACK UP) reassemble
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
SOURCE: briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
SOURCE: Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
