SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
SOURCE: Bobcat 225, machine is idling way to high and will
It could be and the governor sticking to wide open throttle, try the linkage at the full fuel position with the engine off and see if it sticks when in full fuel mode, there could also be an intake leak but would not cause it to run with the switch off that is a different problem. let me know if you need more help.
SOURCE: Can i power this unit with my old Miller Bobcat
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
