SOURCE: Hydro maax wirlpool bathtub Model # J6061 Pump will start
Can either be a bad motor or if the motor has a capacitor, it needs to be replaced. I would call a service professional to come out.
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
