The red tape icon is on the display screen and wont recognize the tape. it wont play or record.
SOURCE: no tape icon when the tape is installed
Have you push down the cassette tray before closing the lid?
SOURCE: canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
SOURCE: Canon XL2 wont record or playback tapes - grey lines.
The video heads may be clogged. Depending on the severity of clogging, if minor, you can clean the heads with the head cleaning tape other option would be manual and direct cleaning by technician. First, open the tape loading area for dust removal by canned air, clean pinch roller with Q-Tip using denatured alchohol and try it. If it did not do the job. Assigne it to a technician for about $99 for a professional cleaning. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
