SOURCE: bernina artista 180 keeps warning to check top thread
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
SOURCE: Do I need to oil the Bernina Artista 170? If so,
- yes \-every 3-5 hours of sewing or more if you are sewing very dirty fabrics (used canvas etc)
-remove the shuttle, clean and oil the "race" where the shuttle ocellates
-remove the light cover with the off set torues wrench included with your machine
oil the needle bar, take up lefver joints and the presserfoot bar. any thing more should be done by a qualified technicial who should remove back and front covers and remove lint and dirt and then oil all the bearings
drtension
SOURCE: Bernina Artista 640 - While embroidering, the
This will probably need to be handled by a professional. With this particular Bernina, you might be able to adjust the needle position so that it is slightly off center and will not hit the presser foot. That would be a temporary fix, however. If you want to be able to thoroughly enjoy your sewing time, you will be happier if you take it to a certified Bernina repair site and let them adjust the needle position.
SOURCE: I need a manual for a Bernina Artista 185 manual
bernina 185 manual and embroidery module manual are available is pdf format on the bernina website. Go to www.bernina.com. Click on "support" towards the top of the page. You will then be taken to a new page. Click on "Search support info for BERNINA models" which in on the left side of page. Then use the drop down to select your model. You should see available pdf manuals available for download. Good luck.
SOURCE: bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
