SOURCE: Pinouts for DPS 1200 eb a /24 pin
CALL A LOCAL COMPUTER CABLING SPECAILIST AND SEE IF THEY CAN HELP YOU WITH THE PIN OUT
NEED MORE HELP CONTACT ME
CANDYMANGANDY
SOURCE: DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
SOURCE: My DPS-730AB A power supply made by delta for my server quit
I need the diagram of the output pins of the source (DELTA ELETRONICS) Model: DPS-730 ABA
SOURCE: hi... my "DPS-800GB A" power
Verify if the voltage switch is in the correct position (110V/220V) in the back of the unit, verify if the power cord is OK, plug it in a different AC outlet
SOURCE: Pinout for dell power supply with model number Ep071298
There are no wires, it's a big hot-swap plug.
