Garden Logo
M
Mike Meyers Posted on May 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to adjust valves on John Deere 320 lawn tractor. Kawasaki motor.
jamessizer
Level 3:
  • John Deere Master 7,515 Answers
  • Posted on Jun 09, 2017
jamessizer
John Deere Master
Level 3:
Answers
7515
Questions
0
Helped
691235
Points
37181
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
5 Related Answers
Anonymous
  • 155 Answers
  • Posted on Aug 12, 2009
SOURCE: John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Anonymous
  • 548 Answers
  • Posted on Aug 22, 2009
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
nova2nv
Bill Linda Rivard
  • 197 Answers
  • Posted on Nov 13, 2009
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Rocky Ridge Mowers
  • 71 Answers
  • Posted on Jan 08, 2010
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Anonymous
  • 124 Answers
  • Posted on Dec 06, 2010
SOURCE: How do I adjust valve rods and what's the
Hi I'm Dane, and I'm going to help you solve you problem. Glad to finally get this answered for you. The piston should be set to top dead center on the compression stroke. Adjust the valves when cold to .004 Intake and .006 Exhaust. Torque spec is 61" lb .If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Fly wheel on john deere saber lawn tractor turns about 2 revolutions then locks up
The typical Over Head Valve (OHV) engines in lawn garden equipment require periodic valve clearance (lash) adjustment. Likely you are experiencing "starter stall" which is corrected by adjusting valve lash to engine manufacture specifications.
1helpful
No valve movement on 320 John Deere lawn tractor.
the jd 320 lawn tractor is fitted with a 2 cylinder water cooled vertical shaft Kawasaki engine
parts numbered -j59051 and , I 59051 show it as a gear driven cam shaft
I would be looking for the rocker arm bolts loose /stripped, bent push rods or the key or the key that drives the crank gear has sheared
9helpful
How do I adjust valve rods and what's the clearances ? Model325 John deere lawn tractor.
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
3helpful
2answers
Aug 09, 2009 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
