Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem -
Ford Tractor 1100 1110 1200 1210 1300 1310 1500 1510 1700 1710 1900 1910...
SOURCE: 1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
SOURCE: Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
SOURCE: lost my tractor key ford 1910
Hi skybird564
You can try at the Ford tractor dealer to see if they have a generic key for your ignition..if not then replace the switch with a new starter switch you can purchase at any auto parts store.
Please take time to rate me
Bud
SOURCE: where do I install the frost plug block hearter on a ford 1910 tractor
-Read its manual.
mai
