SOURCE: Forgotten pass code for parental lock
Try 3308. That is what is shown in the oweners manual I received with my Qwestar 360MVP. If that doesn't work, go to DEFAULTS and select RESET. This should give you the factory initial settings then try 3308 again. Good luck!!
SOURCE: parental control lock
Here is the user manual, check page # 40 on how to clear the secret code.
SOURCE: How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
SOURCE: unlock codes
Found the code on another posting:
1,2,3,4
When the parental block comes up hit play, enter the code, then hit play again...
SOURCE: I ve Forgotten the Lock code please help me
I want to format my n gage, but i forget my lock code !!!!!!!!!!, I using a default code (12345) but isn't work, please help me !!!!!!!!!!!!!!!!!
