I sent the pouch through and it wrapped around the Roller I Opened it cut the wrap up out and when I put it together i get a beep beep beep ect. and thats it. Please email me if you know how to diagnose the beeps . . . [email protected]
SOURCE: how to refit the front brush belt driven roller
hi well if you go onto youtube and look for replace dyson clutch it will show you how to refit your brush good luck
SOURCE: Ran over a cord. Wrapped around the roller brush.
it was the belt should cost a few dollars at bimart or like ace you can do this by taking rollers out from bottom of vac. u can use a butterknife to unscrew it ull see the belt.
SOURCE: I got a cord wrapped around the roller, and now
To unrap the cord from this vacuum you will have to do the following:
First turn the vacuum upside down and place head on counter and handle on the floor. You will have remove the base plate. There are 3 screws that hold it in place. Since cord is wrapped around the brush roller you will not be able to take it all the way off, but it will give you access to the brush roller. If the belt is still on the brush roller, I suggest you cut it, so you can lift the brush roller out of the base and that will make untangeling the cord easy. If you need a new belt here is the info on that.
Style "R" Extended Life. Eureka Part #61110 - Free Shipping
cost is $ 9.99 for one
should have smelt a rubber smell at the same time. The rubber belt probably melted in half. Just flip vacuum over so you can see the bottom. look for arrows pointing to clips or screws. Usually requires removing one panel and the brush. Buy new belt (look on vacuum for correct size or take make and model and name to the store). Just reinstall, replace brush and cover and screws and your all good.
