2008 cub cadet rzt 50 run for 20 min than dies while mowing
put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines
clear
Run for 10 min. great next 5 min sounds like losing power by 20 if i don't turn off pto it dies
First of all, you want to make sure the fuel filter is installed correctly. Then the filter may be restricting the flow. To solve the problem, you half choke the carb. That should take care of it.
Check again piece by piece all that you just replaced to make sure one of then is not faulty from that house.
Check the oxygen sensors
The engine PCM
Catalytic convertor
there is code that does not turn on the service engine soon. have code retrieve.And when the problems occured have fuel pressure check.You have to find out if the problem is electrical or fuel and air .Another way to find it is move engine harness while engine running if it stall could be short to ground or wire cut open
yes try getting the fuel pump pressure tested by a mechanic. the other thing it can be is the injectors are plugged try running some lucas fuel system cleaner.
