My AEG pressure cooker (second one), reverts to "keep warm" no matter what I do. It heats up but the timer does not start counting down, the little full stop keeps flashing while heating then reverts
If your Hamilton Beach slow cooker model 33966C is no longer switching to the "keep warm" setting after the cook time is up, there could be a few possible causes:
The thermostat may be malfunctioning. The thermostat controls the temperature of the slow cooker and if it's not working correctly, it could prevent the slow cooker from switching to the "keep warm" setting.
The timer may be malfunctioning. The timer controls the cook time and if it's not working correctly, it could prevent the slow cooker from switching to the "keep warm" setting after the cook time is up.
The heating element may be malfunctioning. If the heating element is not working properly, the slow cooker may not be able to maintain the correct temperature to switch to the "keep warm" setting.
The lid may not be properly sealed. If the lid is not properly sealed, heat may be escaping and the slow cooker may not be able to maintain the correct temperature to switch to the "keep warm" setting.
It is recommended to try to unplug the slow cooker for a few minutes and then plug it back in to see if that solves the problem. If the problem persists, it may be best to contact Hamilton Beach customer service for further assistance or to have the slow cooker repaired or replaced.
The timer will only start counting down when your pressure cooker has reached FULL pressure. Maybe it has SOME pressure but for some reason the cooker cannot reach the needed temperature. First, remember that this step can take up to 20 minutes, more if the food inside is frozen. Also, take a look at the pressure cooker trouble-shooter to find out if it is an equipment or recipe problem: http://www.hippressurecooking.com/infographic-the-pressure-cooker-trouble-shooter/
The pressure cooker either does not contain enough liquid or the liquid is too thick for it to reach and maintain pressure. Don't pressure cook condensed soups, jarred sauces (salad dressings, tomato sauce, etc) and flavor packets. They all contain thickeners that prevent the liquid in the cooker from boiling, making steam and generating pressure.
it has a stainless steel inner pot, 6 in 1 multicooker, 10 different cooking programs, different adjustable modes, a delay timer, an automatic keep it warm feature, a measuring scale, as well as an 1000w heating element.
The recipe in it does not contain enough liquid, or the liquid is too thick, for it to reach and maintain pressure. Since the heat-up time to pressure is taking too long the cooker is shutting off.
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while
you are out of the house, freeing up your day. Set the timer on a
Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
Fill
the insert of the Corning ware slow cooker with food and cover it with
the lid. At least a quarter of the insert should be filled with liquid
to keep the environment moist during long cooking times.
Press
the "On/Off" button on the left side of the electronic control panel in
the front of the appliance. This will turn on the slow cooker to the
low heat "Warm" setting.
Press
the "Cook Time" button on the right side of the electronic control
panel to add hours to the timer which will show a total time in hours
with a red digital display. Continue to press the button until the
display indicates the desired cook time in one-hour increments up to 10
hours. The cooker will automatically adjust the temperature setting
based on the amount of time you programmed on the timer. Cooking times
of six hours or less automatically start on "High" heat and times of
seven hours or more will start on "Low" heat. A small indicator light
will come on below the word to tell you the cooking temperature.
Yes, otherwise the cooker would blow up from the pressure. This was a common problem with pressure cookers used on a stove from many years ago. Hope this helps!
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
