-You mean the ignition key is lock. So you can't turn the key to start right...?
Try this:
Insert the key into the key slot. then turn the steering left untill can't turn and hold there then turn the key. If it doesn't work then turn the other way and hold then turn the key. You should be able to turn the key like normal.
Good luck
Mai
