First how do you know the battery is good?make sure all cells are good,one bad cell can fool you.you have to have at least 12.4 volts in your battery to pass for good.If you don't have headlights your not getting power to your car.Either the battery is BAD or you have a cable problem.If this it not the case you could have a broken connection between the battery and the power distribution box.
If nothing electrical works, even though the battery is good, it has to be a main power cable.
The main positive power cable runs first to the starter usually, and then to the fuse block.
The negative cable usually goes to the body and the engine block.
