Music Logo
D
Dawn Dudley Posted on May 16, 2017
Trobleshooting guide for casio ctk-720 - Casio Music
farai
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 16, 2017
farai
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
128
Points
9
Look for it on google
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
How to fix ctk 7200 keyboard sdcard erorr
SD or SDHC memory cards must be between 2GB to 32GB
1GB SD card for earlier models or even 2GB SD formatted by earlier models are incompatible (folder structure has changed)
2answers
Computer does not have Ctk-720 driver
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
Can't connect my ctk-720 to my mac
The Mac needs the driver, and you may need to select it in Chooser as well. If it is not on the instruction disk, it should be downloadable from the manufacturers website.
2helpful
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 • Casio Music
20helpful
2answers
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 • Casio Music
Where can i get an instruction manual for my casio electric keyboard ctk-720?
click here
Its available right off the casio website
enjoy
Sincerely,
Michael Scott
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
