Washing Machines Logo
Sophea Ream Posted on May 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My toshiba washing machine model AW-80VE(w).how can i reset the program of the machin? when i turn on it error E71.
Piotr Pachkaev
Level 3:
Master:
  • Master 306 Answers
  • Posted on May 16, 2017
Piotr Pachkaev
Master
Level 3:
Master:
Answers
306
Questions
Helped
106523
Points
1533
Hello!
E 71 is an error of a temperature sensor.
Most likely, there the contact was interrupted or there was a short circuit of the sensor and / or circuit.
4 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Feb 01, 2011
SOURCE: Toshiba auto washing machine model
Hi.
E2 is not an error code. It means that the Spin only mode has been started and that the cycle is now over.
To reset the machine try disconnecting power (trip circuit breaker), connecting back, then hold down the Super Spin Dry button while you start the machine at the same time (press On while holding the other button). You should hear three beeps and the machine will be reset to initial settings.
Anonymous
  • Posted on Aug 28, 2011
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
williamsa43
  • 164 Answers
  • Posted on Feb 09, 2015
SOURCE: Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
appliancexch
Ken Wieczorek
  • 451 Answers
  • Posted on Jul 03, 2015
SOURCE: error e7-4 toshiba washing machine aw-b1000gb
Buy american LOL Toshiba is top secret stuff
Toshiba washing machine model AW-DUJ1700DBUPQ turns on, beeps with error code "EL" then shuts down within 5 seconds.
you seem to be the only person with an EL Error, although some report it is E7 upside down! Change my Google search query to E7.
https://www.google.com/search?q=Toshiba+AW-DUJ1700DBUPQ+beeps+with+error+code+%22EL%22
Not much information of a Reset Procedure either. The standard way is to pull the plug overnight.
https://www.google.com/search?q=Toshiba+AW-DUJ1700DBUPQ+Reset
2answers
Toshiba AW-J800AUPB 7 kg. What does e71 error indicate?
Try reset..
water flow+preset+rinse+on...... do it all at the same time.
2answers
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
9helpful
4answers
Toshiba washer show error E71 , what is the problem ?
Try to reset..
water flow+preset+rinse+on.. do it at the same time.. also happen to my toshiba 11 kg .. alhamdulillah it ok sangat..
Toshiba washing machine AW-A750SM error LED blingking power off
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website.
or try this link.
Reset Buttons for Washing Machines
or this link.
https://www.google.com/search?q=Toshiba+washing+machine+AW-A750SM+error+LED+blingking+power+off&rlz=1C1AVFC_enGB797GB798&oq=Toshiba+washing+machine+AW-A750SM+error+LED+blingking+power+off&aqs=chrome..69i57.606j0j8&sourceid=chrome&ie=UTF-8
My washing machine Toshiba Aw SD160s is not working. It show E71
My aw-sd160s todhiba washing machine was showing code E-21 ?? does spin?????
3answers
73helpful
7answers
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Top Washing Machines Experts
john h
