Model # lmv2083st
Fuses are normally internal on Microwaves and opening the cabinet exposes dangerous voltages, even when disconnected.
The fuses used are 'Ceramic' and look like this.
However, just replacing it may not fix the problem, if you have a shorted component inside, it will need to be repaired by a competent shop/technician.
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps.
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
