SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
SOURCE: Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
SOURCE: Seagate External Hard Drive powers down after being idle.
If you load the Free Agent Software, there is a utility for setting the power saving. You can set it to a number of different times including never. The default is 15 minutes. I think this is what you are experiencing. The settings are in the Utilities tab.
SOURCE: Seagate external drive locked in "read only" ,was working fine...
This seems to happen when it's been connected to another computer. Are you running FreeAgent Sync? If so force a sync and the read only problem should go away.
