Question about Husqvarna Garden
My husqvarna wont go forward or reverse good I keep moving the 2 steering arms and it will move but not like it suppose to could it be the v belts and where are they located at
    Master:
  • Husqvarna Master
  • 653 Answers
If the unit stopped at once, it is probably the belts. Check under the mower, they route over the wheel pump motors at the rear of the mower. Looking underneath from the rear you will be able to see the belt(s)
Posted on Jan 02, 2018
SOURCE:
SOURCE: 1320 cadet mower wont move good in reverse
**** u **** ur self
Posted on Mar 19, 2009
  • 4 Answers
SOURCE: 92 camry wont move forward
no, you need a transmission, A used one cost about 3 to 4 hundred dollars at the junk yards
Posted on Apr 06, 2009
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Posted on Jun 18, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
SOURCE: key wont come out of ignition in 1998 saturn sl2
I had difficulty with my key in my 98 sl1 too but I discovered that I just had to push on the shifter until you hear it click, then you could jimmy the key a bit to get it out.
Posted on Nov 17, 2009
MY HUSQVARNA YTH24K48 MOWER WILL BARELY MOVE FORWARD OR REVERSE. I CHECKED THE FREEWHEELING MECHANISM AND IT WAS WORKING PROPERLY. LOOKING UNDER THE MOWER AS WELL AS I COULD, IT SEEMED FINE.
sounds like the drive belt or belts are worn out. replace both in order for it to work properly .replacing one wont work. replace them as a pair.
Nov 05, 2016 | Husqvarna Garden
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
Clutch adjustment
I had the exact same problem on my Husq 2148 which arose just after a new drive belt was put on. There is a cage around the front, engine, pulley which keeps the belt from flying off I guess. After staring at the belt for a long, 2 beers, time I discovered the repair guy had put the belt inside the cage on one side, where it is supposed to be, but outside the cage on the other side. This caused the problem you described and it ran much better in reverse than forward. If your problem arose after a belt change, I would start looking there, if not then I would check the 2 springs which keep back tension on the pedal. It took me 3 more beers to get the thing put on right.
May 30, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
My huqvana won't go in reverse or forward
if the leaver moves freely but wont move first check belt is on pulley and if so you have sheared off keyway on the pulley on top of drive axle remove pully replace keyway reinstall
Jul 26, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Garden Logo
144 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
lnbn1975
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
