DStv
https://www.dstv.com
The best in television entertainment at your fingertips. Watch the latest sport, movies, series and reality shows and access the DStv TV guide.
Watch the latest sport, movies, series and reality shows and access the DStv TV ... hottest entertainment channel, tVN (DStv channel 134), is now in South Africa ...
DStv Self Service · Get DStv · DStv Hardware · DStv Agencies
If you are a DStv customer in a country within our DStv territories, the DStv app enables you to stream live TV, catch up on your favourite series, movies and sport ...
Rating: 4.1 · 148,572 votes · Free · Android · Entertainment
I havDUEL VIEW DSTV and it went on the blink, I kinda fixed TV1 but on the second TV which is LG after I AUTOMATICALLY RESET IT shows only 4 channels sabc 1 2 3 and etv, so now i cant see dstv and i cant find a channel for it, how do i get it back as it was working fine on tv 2?
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
