L
Linda Rachal Posted on May 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer windows 8 wont recognize my archos 104.what do i do?
SmartAviator
Level 3:
Genius:
  • Archos Master 1,124 Answers
  • Posted on Dec 14, 2023
SmartAviator
Archos Master
Level 3:
Genius:
Answers
1124
Questions
0
Helped
194544
Points
2636
Centos is a good replacement for windows users.
ADMIN Eric
Level 3:
Top Expert:
  • Archos Master 39,388 Answers
  • Posted on Dec 08, 2023
ADMIN Eric
Archos Master
Level 3:
Top Expert:
Answers
39388
Questions
0
Helped
804819
Points
588736
Windows 8 is and has been obsolete and unsupported for over 8 years.
Time to update your OS.
Linux is excellent, Ubuntu Mint is free and easy to use, the choice is yours.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Aug 08, 2008
SOURCE: Archos 504 huge problem
I had the same problem. I droped mine and it seems to have messed up my hard drive. i replaced it today and my comp. can now reconize it. i have been trying to contact tech. support to see if it is possible to get the OS back on the PMP. if the Tech support ever picks up my call i will message back with the fix.
Anonymous
  • 196 Answers
  • Posted on Sep 30, 2008
SOURCE: picked up my Archos 104
sounds like the battery has been allowed to discharge totally this is not good for certain types of battery despite what some people may think.. some modern bateries require at least a residual charge to keep it healthy enough to receive a whole charge
Anonymous
  • Posted on Jan 16, 2009
SOURCE: code 104
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Anonymous
  • 2418 Answers
  • Posted on Sep 18, 2010
SOURCE: I dont have the manual my MP3 104 came with
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
Next:-- Refresh the driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. NOTE: - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Next - Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. ffffff
Anonymous
  • 8909 Answers
  • Posted on Jan 16, 2011
SOURCE: windows xp wont recognize my
That is because USB drives were not available in 1999/2000 when XP came out and there are limited drivers for them.
See if there is a driver on archos.com
Hope that explains it.
I cannot accesss my archos av400 20GB via usb. I tried different cables. If I select Hard drive, windows dont detect my archos at all but when I select windows device, my windows detect the archos but not...
Your windows is installed on FAT 32 partition, so it is not recognized partitions bigger than 4 Gb. Change to NTFS. ATTENTION ! All informations on your computer will be lost. Do this only after saving your private files !!!
I dont have the manual my MP3 104 came with because it was a gift but how can I get my computer to recognize it again Correction: Archos 104
3helpful
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
2answers
After formatting the archos5 ,the device doesnt get recognised
* When the white option screen comes up, just pick the format disk
Getting a white screen with 102 error message
Picked up my Archos 104 for the first time in 8 months as I had changed jobs, but find it takes fore ever to boot up, then wont let me carry on to play my music. It then shuts down. any ideas??. Ken
1helpful
3answers
Archos 404
Archos is not claiming compatibility with vista, even with their latest firmware upgrade - sorry
How do i put music to my archos?
try going in to whatever music player program your computer offers and to to file.... browse...... my computer..... and there should be a usb drive if its pluged in it will say archos.... click on it...... and select open.... then it will come up you can then transfer music to it just like any other drive or folder on your computer try windows media player go under the sync option then just drag and drop
2answers
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
