SOURCE: how to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
SOURCE: nike heart rate monitor triax c5
I was able to view the instructions here: (no title)
http://www.klokker24.no/ressurser/1183.pdf
SOURCE: I need a wristband for my watch nike triax
NIKE contact address: USA 888-350-6453, Nike Timing Service Center, 7501 N.Harker Dr., Pearia, IL 61615, www.nikewatchrepair.com
SOURCE: turn off hourly beep on nike triax fury
Press the Start/Lap button in Time mode to turn on/off. This also turns on/off the beeping sound when switching between the different modes.
SOURCE: Can I run Nike Triax Elite software in Windows 7.
I had to take the following steps to get it to work in Windows 7 after running the setup executable under the Comments in the Windows row from http://www.ftdichip.com/Drivers/VCP.htm
Windows then finds another Unknown Device which is the serial port. Repeat as above but choose Ports for the common hardware types and then FTDI and "USB Serial Port".
Afterwards, run the latest Nike Triax Elite software (that you can download from http://www.nike.com/timing/extranet/elite_software/ and it should work.
