Before you do anything, Contact Whirlpool service with your model and serial number. There and many recalls on their Cabrio washers for control board problems.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control. Check these things out: Drain pump fouled/clogged Drain hose too high for propah pumpin. Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
F32 is a long drain fault code. Tip your washing machine back far enough that you don't have to hold it up. At the back of the unit there are two "things" with hoses coming out of them attached to the bottom of the outer tub. On the left is the recirculation pump, and to the right is the drain pump. Take a wet/dry vac and get as much water out as possible through the end of the drain hose, then pull the hose off the drain pump, remove the pump, and look for coins/shoelaces/whatever might be blocking it on the inside.
What make and model is your washer? This applies to Whirlpool cabrios. Just reread your message and realized that I have no idea what you're talking about. F codes are pretty common in different brands, but "32" could mean anything. All depends on what you're looking at.
