Fault Code Definition
The Manifold Absolute Pressure Sensor/Barometric Pressure Sensor measures the rise and fall of the air pressure inside the Intake Manifold. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, and many components of the Emissions Control Systems. The Manifold Absolute Pressure/Barometric Pressure Sensor P0106 code is set when there is a problematic or erratic performance in the voltage signal to the PCM.
Symptoms
Common Problems That Trigger the P0106 Code
Common Misdiagnoses
