Question about Nikon D60 Digital Camera
Brand new D60: This battery cannot be used.
Hello. I've just opened my brand new D60 and having charged the battery the camera posts the following message: ''This battery cannot be used. Choose battery designated for use in this camera.'' We own another D60 in the family and the new battery works in the old camera but the old battery doesn't work in the new camera. This suggests to me that the battery isn't the problem afterall. Is there something else we could try.
  • msiclegg Jul 25, 2009
    Thanks for the comments. The battery is NIKON lithium ion as supplied int new box.
    It works in an identical D60 camera so I'm pretty sure it is the correct one.
    The suggestion to change the battery mode could be a useful one. The only problem is the machine won't let me change any settings because the battery is incorrect. Is there any way of checking the settings?
    Ac power? The only other cable supplied is a pc cable which doesn't seem to provide power. I can find sn ac slot on the camera either?
    New Friend:
This battery cannot be used Choose battery designated for use in this camera
Posted on Sep 15, 2012
  • 4,924 Answers
Yep ...look in the menu ...of the camera ..and select the type of battery u are using ..there are 2 kinds of batteries ...one of them are alkaline ...and the other I'm not sure ..probably nickel or lithium ..or something like that ...anyway there are choices there ..and you just have to try 'am one by one ...
it will also accept only high quality non chargeable ones ...so ..even if they work in other device ..in this kinda cameras it will see 'em as empty if they arent great in quality and amperage ...
Posted on Jul 25, 2009
  • 2 more comments
  • Catalin Turcu
    Catalin Turcu Jul 25, 2009
    The
    D60 uses the same Nikon EN-EL9 Lithium-Ion (1000 mAh at 7.4 V) as its
    predecessors. Nikon claims a fully charged EN-EL9 carries sufficient
    juice to power the D60 through up to 500 exposures (with the kit lens
    mounted and VR engaged, occasional flash use, and regular LCD image
    review).
    The (included) Nikon MH-23 charger needs about 90 minutes to fully recharge the battery.
  • Catalin Turcu
    open it with the ac charger on...
  • jawadmund
    jawadmund Sep 15, 2012
  • jawadmund
SOURCE:
D60 will not turn on - why?
If the camera has only been off for a few months, I would recommend that you take the camera and the battery to a camera shop, verify that the current battery is holding a charge and then check the camera with another battery.
Dec 25, 2014 | Nikon D60 Digital Camera
I've used the Quantaray PZ-1 DSZ on my Nikon N80 film camera and had no problems. I would like to use it on my digital Nikon D60.
There is no problem with the trigger voltage, which I assume is your primary concern. You may not get all of the features you would with a Nikon flash, but you should be able to use it with the D60 just as you use it with the N80.
Jan 05, 2013 | Quantaray PZ-1 DSZ for Nikon TTL Flash
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
I am having a Nikon D60 DSLR Camera. I am using it for more than 3 year now when I am loading the battery in the body. The message says "This battery cannot be used. Choose battery designated for used...
Your battery may be worn out and is unable to get re-charged. Buy a new battery for your camera, or try your battery in a matching camera to verify that it is depleted, if so try a new/other battery in your camera to verify that you need a new battery.
Jul 27, 2011 | Nikon D60 Digital Camera
Nikon D60 won't turn on and the battery is charged, i'm getting nothing at all. The camera was left on for an extended period of time, is it possible the battery is dead. the camera is only six months old
Usually, when your battery has been in the charger long enough for it to be fully charged, the indicator light either changes color, or turns off. This indicates that the charge is complete.
Does your light do either, change color or turn off?
If neither of these works right, check your user manual, usually in the back, which will tell you what the indicator lights mean.
If your camera and battery are doing what they are supposed to be doing, then you may have bought a faulty camera, or the battery which came with it was faulty.
Be certain to read the manual very carefully, to be certain that you are following the instructions properly. If you have done everything right, then return the camera and or battery to the place from which you purchased the camera, and have them check it out to ensure that all is proper.
Dec 30, 2009 | Nikon D60 Digital Camera
WHY DOES MY NIKON D60 BUILT IN FLASH FAIL TO WORK IN DARK SORROUNDINGS AFTER BATTERY CHARGING AND DESPITE HAVING ALL SETTINGS IN AUTO MODE?
Hello
Thank you for using
FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Will the carama charge while plugged into the
No it will not charge.To get a reliable charge remove battery and use supplied charger
Jul 18, 2009 | Nikon D60 Digital Camera
Shutter speed and apertue not working for Nikon D60 Digital SLR
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
Mar 08, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Battery Problems
This suggests a major short circuit. Check the the battery contacts in the chamber are clean and not obstructed. Then post this query to the Canon Technical Help team
Jun 06, 2007 | Canon EOS-20D Body only Digital Camera
Nikon D60 Digital Camera Logo
1,367 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
