SOURCE: Type of power supply and what where is the +/- 5v or color coding for the 4 pin connector?
Dhen: This monitor uses a special Power Adapter as shown... Also the Pin designation is from the NOTCHED PART BEING ON TOP: NOTCH U +V O O +V GND O O GND SithPitt
SOURCE: Creative Gigaworks S750 9 pin color code
Cliff
First things first:
This is not a special and critical eq. from creative, you can take it to the reapair shop and they sometimes have the schematics, other than this, sorry you have to RMS to CREATIVE.
Carl
SOURCE: Can't locate Intake Air Temperature Sensor Connector
The IAT is integrated with the MAF (Mass Air Flow) sensor all one unit the following diagram should help
SOURCE: the connector does not match the wiring harness connector for car
you can buy wiring harness adaptor from any car audio shop or try Ebay.
SOURCE: Replacing oem car radio/CD (Clarion PN-2165M I)
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
