Question about Bunn Coffee Makers & Espresso Machines
Bunn not used in a year. Now the water heats to only lukewarm after two hours. Is this situation hopeless?
    Scholar:
  • 135 Answers
The heating coils may be calcified. With the machine off- pour some vinegar into the water tank. Let it sit over night. then pour clean water in and run it at least 3 times to flush out the vinegar.
Posted on May 06, 2017
5 Suggested Answers
SOURCE:
SOURCE: Our Bunn VPR coffeemaker takes a LONG time to heat
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Posted on Jan 06, 2010
  • 349 Answers
SOURCE: water is lukewarm.
Make sure you have power going to elements from thermostats. check lines going to elements.
Luke warm water is the result of an element gone bad most of the time. One at th etop gone will cause you to get just luke warm water and one at the bottom gone will give you real hot and then cold.
The elements are not to exspensive so if it has two you might as well replace both of them. If you just put 1 new one in it will work the old one till it goes.
Cut power off and cut water off to water heater and drain heater, open hot side on any faucet to help it drain. once drained remove element they have a tube type socket at hardware stores for the removal of it.
Put elements in and fill water heater till all air is out of lines before turning power back on. make sure water is flowing out of all faucets before turning power onto water heater.
The reason being is the elements has to be in water not open air in tank or it will blow new ones.
Posted on May 16, 2010
  • 115 Answers
SOURCE: bunn-o-matio model btx-b does not heat water
Hi, Sounds like a boiler therostat or faulty boiler. Dazza REPAIRER
Posted on Sep 24, 2011
  • 5353 Answers
SOURCE: Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 01, 2012
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Dec 30, 2016 | Bunn Coffee Makers & Espresso Machines
My Bunn Coffee maker is leaking water from the bottom.
I had the same problem. On mine (and probably yours) the problem was the seal between the (upper) plastic water reservoir and the lower (metal) heating reservoir. No replacement seal is available.
I fixed mine by coating both sides of the old seal with aquarium grade clear silicone sealer - available at pet supply stores. Just a light (1/16") coating is all that's required. Carefully re-assemble and allow the sealer to cure for 24 hours.
I did that over a year ago, and it hasn't leaked a drop ever since.
Sep 25, 2011 | Bunn GR10 Coffee Maker
Lukewarm water...tank empty...how do I fill it if it is supposed to fill automatically from an outside line?
It looks like this brewer has a fill lid on top. If you remove the screw on the lid you can remove it and pour cold water through (1/2 gallon per pot). If the brewer was energized and NOT filled with water before hand there is a good chance that the heating element burned up. The reason you would still get "lukewarm" water is due to the keep warm heater around the tank. It is a low voltage warmer that keeps the reservoir warm without the main heating element kicking in.
Aug 25, 2010 | Bunn CRTF5 Coffee Maker
Our office is relocating and I need to prepare our Bunn coffee maker to be moved. It appears to be working fine now, but we do live in a hard-water area. So: - Obviously we will be unplugging it. Can it be...
I work for BUNN. Yes, you can empty it - here's a link to instructions http://www.bunn.com/retail/service/faq.html#faq6
Also, it's absolutely a perfect time to do the Periodic Cleaning of your brewer - here's a link to instructions for using vinegar to thoroughly clean your brewer. http://www.bunn.com/retail/service/cleaning.html
If you want to move the brewer without draining, please be sure to unplug it and let the water cool for about 6 hours before moving it (the water inside is 200 degrees). Then, when you get to the new location you can just plug it in and let it heat up.
Any other questions, please let me know. lisa.mccloud@bunn.com
Feb 01, 2010 | Bunn GR10 Coffee Maker
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
Jan 05, 2010 | Bunn VPR Coffee Maker
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Coffee Makers & Espresso Machines Logo
48 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
