I purchased my new LG phone, which is very nice and works great. Did not think to set up voicemail for about a month. When I tried, I got an error message from VERIZON: "This # has not been dialed correctly. Please hang up and try again." I had dialed "1"
This first happened about a month ago. It took about 20 minutes to "fix" and about a day later I set it up, and I thought I set it with my previous password.
Today I saw I had a voicemail waiting, so dialed #1, and again got the error message from VERIZON. Again I spent about 20 minutes with customer service fixing the problem. Now I gave to dial *86 to reach my box. However, they did not accept the voicemail I typed in. I tried the one other #s that I might have used, but it did not accept that either.
Where do I go from here?
The "Password Skip" feature lets get into your voicemail without entering your voicemail password. This feature only works when you call into your voicemail from your Virgin Mobile phone.
Here's how you can set up Password Skip for your Virgin Mobile Voicemail:
1. From the main menu, please press 3 for personal options. 2. Then press 3 for mailbox setting. 3. Then lastly, please press 2 to turn password skip on or off.
It is best to have password skip so that you won't have any problem even if you forgot your password.
Hope this tip helps! Please don't forget to rate! Have a great day!!!
You'll need to go to your carrier or call in and ask that they reset the password as it is a Network setting and not something that is attached to that specific phone (which is why when you get a new phone with the same phone number, the voicemail transfers over)
I think you'll need to go into menu - settings and tools - sound settings - alert tones, then it should give you choices on what you want to change. Text, Picture, Voicemail, etc...
Internet Setting Cingular: Profile Name: Cingular GPRS setting: APN: wap.cingular User Name: WAP @ CINGULARGPRS.COM Password: CINGULAR1 (ALL UPPERCASE) Time Out: Off Primary Gateway IP: 66.209.11.61 Port: 9201 Secondary Gateway IP: 0.0.0.0 Port: 0 DNS Server:BLANK CSD setting:BLANK Dial in number NONE Query at Logon: (NO CHECK MARK) User Name Password Baud Rate Auto Line Type: ISDN Time Out Off DNS Server: Then go to your browser and enter the following settings: Profile Name: MEdia Net Homepage: device.home Network Link: Cingular MMS Settings: Profile Name: MMS over HTTP MMSC: http : //mmsc.cingular.com/ (No Spaces) Max Sending Size: 30K Network Profile: Cingular
Internet Setting T-Mobile T-MobileWeb Settings: Primary IP Address: 216.155.165.050 Secondary IP Address: (Blank) Access Point Name (APN): wap.voicestream.com Data Bearer: GPRS Profile Name: GPRS Username: (Blank) Password: (Blank) Home Page: http://wap.myvoicestream.com Picture Messaging Settings: Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS Validity Period: 72 hours Hide ID option (if option exists): set to off, no, or disabled
Internet Setting FIDO Profile name: FidoWAP GPRS setting: APN: wap.fido.ca Username: fido Password: fido Timeout: 15 minutes Primary Gateway IP: 205.151.11.11 Port 8080 Secondary Gateway IP: (blank) Port: (blank) DNS Server: (unchecked) CSD Setting: Dial in number: (blank) Query at logon: (unchecked) Username: (blank) Password: (blank) Baud Rate: Auto Line type: Modem Timeout: Off DNS server: (unchecked) Then press Save. To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified) Setup-->Data Network Profile Name: Fido MMS APN: mms.fido.ca Username: fido Password: fido Timeout: 15 minutes Primary Gateway IP: 205.151.11.13 Port: 8080 Baud Rate: Auto Line type: Modem Timeout: off Then click SAVE. THEN Messages-->Service Setup-->Multimedia Message Default profile: FidoMMS (all other settings are to your preference) Tap the box beside Default Profile and ensure that FidoMMS is the default profile. Settings for MMS profile goes Profile name: FidoMMS MMSC: http://mms.fido.ca Max Sending Size: (your preference) Network Profile: Fido MMS
Internet Setting Rogers Proxy Name: Rogers MMS Proxy Address: 172.25.0.107 Access Point: Rogers MMS Home: ((Set whatever page you like here)) Port Number: 8080 Authentication Type: HTTP-BASIC User Name: media Password: mda01 Access Point Name: Rogers MMS APN: media.com Authentication Type: PAP User Name: media Password: mda01 DNS: <> Linger Time: 180 MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings) Profile Name: Rogers MMS Proxy: Rogers MMS Relay Server URL: http://mms.gprs.rogers.com
Master Reset Dial the following 2945#*#6 or 2945#*45#
If u are getting these types of pop up then YoU need to contact 1.ur service provider's helpline and u will get the proper soltion whether there are any voice messages for you or not.
2.I f thereare no messages then reset the settings of your handset.1.Menu>>settings>>master reset>>reset settings (default code :0000) 3.After that if both solution doesn't work then scan ur handset with antivirus.
4.U just flash ur handset from service centre of LG
