Solomon Junior Posted on May 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I fixed the Aficio MP4000 toner replacement. On the screen there is an error code SC863-06. Can you explain what this error code mean?
Deneen Lewis
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 42 Answers
  • Posted on May 06, 2017
Deneen Lewis
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
42
Questions
0
Helped
19195
Points
247
Here is a pdf of all the ricoh error codes:
sc863-06 means
Returned, Bad sector in hard drive
http://www.mtechsinfo.com/files/Ricoh%20Error%20Code%20List.pdf
Ricoh Aficio. How I clear SC390 code? Print is clear, after 10 copies SC390 code is coming. How do I solve this problem please?
Question edited tor a lot more clarity and add MAKER, but NO MODEL NUMBER! All questions need full make and model.
Ricoh Aficio 200 - Error Code: SC390
PrintCopy .info https://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
SOLVED: How fix sc390 cod of ricoh
Fixya https://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Error Code sc 390
Copytechnet https://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
RICOH Error Code List - mtechsinfo.com
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF SC-390-2. Toner density sensor error. SC-391. Developer bias problem or FU103 on Aficio 550/650 Image storage address error. Aficio 551, 551P, 700, 700P.
14 pages
Solve error code sc360 aficio mp4000
When you replace developer, make sure to clean the waste toner path on the PCU. Waste toner in combination with new developer causes trouble. After replacement of the developer use a piece of paper to block waste toner from falling into the DV-Unit. Then run SP2-801 and do process control.
Then make 100 copies and after that remove the piece of paper. A Ricoh tech told me that the amount of toner in the developer can be very high, so he always made 100 copies before removing the piece of paper. I'm doing this for a long time and I never had trouble with SC's related to TD-sensor.
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
1helpful
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
5helpful
2answers
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
1helpful
WHAT DOES THE ERROR MESSAGE 377 MEAN?
It means that there is Magenta toner density sensor error.Try to reset or replace Magenta development unit and then turn the printer off and back on.It should fix the problem,providing that the Magenta toner supply channel is not clogged up and functioning properly.
2answers
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
2helpful
2answers
Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
3answers
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
