It is a low speed, but I wonder if I can reset it or otherwise try something to fix it.
Is this a home model and did you buy originally? the reason I ask is that Landice home L8 models have a lifetime parts warranty. contact Landice and they will be able to assist you over the phone for free. you either need a new keyboard panel(bad buttons), or a new lower computer board. both easy fixes on a Landice
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
SOURCE: printer shut down and won't turn on brand new
try unplugging everything that is plugged in. Ethernet cable phone cord or usb cable too. these things are very sensitive. I am getting the same error message and think I have traced it down to the wireless router I am using. I can print fin from the desk top I have hooked up but when I try to use the other wired port or the wireless with my laptop and print it immediately gives me the same error. I can talk to the printer from every computer I put on the network but when I print from anything but the desk top(hooked up through a hard line on the router too) it gives me the error. If I get anywhere on this I will post what I find as it may help you out too.
SOURCE: WS-55511 shut itself down while watching TV and
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Testimonial: "The lights flashed as follows - 1 blink pause 2 blinks pause 1 blink pause 2 blinks and so on.. total five sets of 1 blink pause 2 blinks pause"
SOURCE: We were watching TV and the TV just turned itself
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
