Question about RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh
8300 wont boot up
It just shows a battery with a red line through it, battery is fully charged. how do i fix this?
  • 70 Answers
Have you tried a different battery? Is the battery swollen, indicating it is damaged?
Have you tried booting up the phone with only a charger connected (remove the battery), this will tell you if it is the battery or the phone.
Posted on Jul 25, 2009
SOURCE:
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
My iphone wont charge it shows minial red line starts after 2seconds but wont charge and switch off again
You need to let it sit like that for 20-30 minutes before trying anything. The battery needs a minimum charge before it will start. If the battery gets too low, it will show the "minimal red line."
After 20-30 minutes, it should be able to start up again.
Feb 21, 2011 | Apple iPhone Smartphone
How will i know if the batt. is fully charge
Hello
Every phone has their own way to show the charging, Normally the running dots/line in the battery will show charging and stop this action will be the indicator of full charging.
Some phones shows the level of battery with colors, like red for empty and green for full images?q=tbn:and9gcrwklg9zmcido0et2bosnkz1j-trcwv6qjon7gf5ffz4alt-gtg Hope this helps if so do rate the solution
Jan 06, 2011 | Samsung Cell Phones
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Blackberry wont turn on just shows red line through battery
Sounds like the display. There is a warranty on the unit. Contact your provider to find out what your service and replacement options are.
Dec 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
Phone wont power on
i have a change my password and many time i type wrong password then my handset not work
its show jvm error 513
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Won't turn on
Have you recently installed a 3rd Party application? The fix will be to reinstall the handheld OS.
** Please remember to do a device backup first before attempting the OS reload.
Oct 11, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8310
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
DOOR WONT EJECT AND ZOOM NOT WORKING
JVC GR-AXM310
Will not eject!!! I have put in a fully charged battery and tried to eject it, it will not open at all. Please help me out if you can.
Thanks Shorty_007
Jun 07, 2008 | JVC GR-AXM310 VHS-C Analog Camcorder
RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
426 people viewed this question
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
