Cummins generator set will occasionally encounter generator failure in the process of use that Cummins generator set is not generating electricity. What is the cause of it? And what to do about it? In fact, there are a lot of reasons that Cummins generator set is not generating electricity.
1. Wrong connection of generator set. Processing: check and correct by wiring diagram.
2. Generator speed is too low. Processing: measuring speed and keeping it at rated value.
3. The connection between the stator winding and the generator distribution equipment has sludge or oxide, the connection screw is loose, the connection wire is broken, and the stator winding is broken. Handling: use a multimeter or lamp test method to find out where the wire is broken. Check the connection and contact of each connection screw.
4. Excitation circuit broken or bad contact. Processing: use multimeter to identify broken wire and reweld the broken wire to bind insulation.
5. Rectifying tube (including rectifier diode, thyristor) is damaged. Treatment: replace damaged parts.
6. Brush contact with slip ring bad or brush pressure is not enough. Treatment: clean the surface of the slider ring, polish the brush, make it match with the surface of the slider ring, increase the brush pressure.
7. Brush grip rusts, brush can not slide up and down. Treatment: wipe the inner surface with a cloth brush, if damaged, should be replaced.
8. Cummins generator exciter brush position is incorrect, brush damage or spring pressure is not enough. Handling: adjust the brush to the correct position, replace the brush, adjust the spring pressure.
https://www.dieselgeneratortech.com/cummins
