SOURCE: I have a eu3000is. It's only 3 years old and has
Hi there .
All the Honda generators have 2 years full warranty (parts and labor) . Just check with your Honda dealer and make sure they call Honda tech support before any decision or you can call customer support @ 770-497-6400
and see if they can get warranty for your machine .
Hope this help.
SOURCE: i am looking for an owner manual for my honda
http://www.hondapowerequipment.com/products/manuals/Default.aspx
Here is the link to download for your particular model from Honda"s website. You may want to get your serial number to refine your search. Good luck and safety to you....
SOURCE: My honda eu 1000 is burning a lot oil. What should i do?
You either have bad piston rings or bad valve seals. A problem as bad as you say will not be a cheap fix, unless you can do the repairs yourself.
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
